Benny2130 Posted July 13, 2016 Share Posted July 13, 2016 Hi All, I'm at the sharp end of purchasing this pedal. I run nearly 90% distortion in the band I am for our songs I do however have one question I want to be sure of before I buy this unit... Can you run in ur fx line with distortion and a phaser/flanger at the same time? It's for like a 10 second part of one of our songs. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 13, 2016 Share Posted July 13, 2016 Yes you can run a distortion and a phaser or flanger (not both) FX at the same time. The HD300 is designed with three variable FX blocks named FX1, FX2, and FX3. Each block is restricted to certain FX selections and you can select one FX from each block. Since DIST and MOD FX are contained in two different blocks you can select one of each to appear in your signal path. Quote Link to comment Share on other sites More sharing options...
Benny2130 Posted July 13, 2016 Author Share Posted July 13, 2016 Thanks guys it's pretty much the same as the me-70 I am borrowing in the way the blocks are run Quote Link to comment Share on other sites More sharing options...
