Troy1g Posted August 26, 2013 Share Posted August 26, 2013 Hello, Do I have to absolutly upgarde my firmware to have the ability import files from an SD card? also do they have to be .Wav, or can they be MP3 files for the JM4? I Have version D.SP 2.00/MCU 1.05 Thanks to all. Troy Quote Link to comment Share on other sites More sharing options...
PHLIAUZUN Posted October 1, 2013 Share Posted October 1, 2013 Hello Troy, One certain point is that you can only use WAV files. MP3 aren't supported. If you want more informations, take a look at the JM4 avances guide wich is only about SD issues. http://fr.line6.com/support/manuals/jm4 For the firmware, I dont know but if you can't import WAV files maybe you have to upgrade.... Quote Link to comment Share on other sites More sharing options...
Steve_Wilson Posted February 16, 2014 Share Posted February 16, 2014 16-Bit Mono 44.1KHz .wav files are the type file supported. You can always convert the MP3 into a WAV file format or vice versa. Audacity is free, open source, cross-platform audio software for recording and editing sounds- it is Freeware.It works on Windows: 2000, XP, Vista, Windows 7, and Windows 8. :) Audacity is a free, easy-to-use, multi-track audio editor and recorder for Windows, Mac OS X, GNU/Linux and other operating systems. Record live audio. Record computer playback on any Windows Vista or later machine. Convert tapes and records into digital recordings or CDs. Edit WAV, AIFF, FLAC, MP2, MP3 or Ogg Vorbis sound files. Cut, copy, splice or mix sounds together. Change the speed or pitch of a recording. And more! See the complete list of features. About Free SoftwareAudacity is free software, developed by a group of volunteers and distributed under the GNU General Public License (GPL). Quote Link to comment Share on other sites More sharing options...
Troy1g Posted March 2, 2014 Author Share Posted March 2, 2014 Question. What is purpose of the Loop FX mode. What is Loop FX in general? thanks to all in advance. Troy Quote Link to comment Share on other sites More sharing options...
Troy1g Posted January 1, 2016 Author Share Posted January 1, 2016 Hello, Finally Trying this again. I converted the backing track to a .WAV but when I go to load the WAV file from the card I get a message that says Wav File must be 16 bits 44110 HZ Mono, I am attaching my the specs regarding my file, Any thoughts would be appreciated. Also does anyone have some go to WAV files that work with the JM4 in other words some good cover tune backing tracks? Thanks Troy Quote Link to comment Share on other sites More sharing options...
patternbass Posted March 10, 2019 Share Posted March 10, 2019 I just bought a used JM4. Still learning. Perhaps a solution to the MP3 issue is to plug your mp3 play into the mp3 in on the JM4, record the song or a portion of the song using the JM4 record function, then save that recording to the SD card. I assume it would save it as a .WAV file format. Now you could load that song, add overdubs etc. Also note: the newer iPhones did away with the 3.5mm plug in. You'll have to purchase an audio adapter that has 3.5mm male adapter on one end and the iOS lightening adapter. About $6. Quote Link to comment Share on other sites More sharing options...
