How? Flashback X4, Pigtronix Polysaturator Into Hd500
velochrome
How can I insert the Flashback X4 (a multi delay) and Pigtronix Polysaturator (a multi distortion) into the HD500. I was planning on using the FX Send/Return path but I would be straying from the standard signal chain of overdrives/distortion before amp and modulations/delay after amp as the FX/Send connection allows only one external pedal and I can't simply put both external pedal into this path.
Why the Flashback X4 and Pigtronix Polysaturator? I always seem to be overwhelmed by the Delays and settings in the HD500 and the Poly makes adjustments on the fly fairly easy.
Have you tried this signal path:
Guitar -> Pigtronix -> HD500 Guitar Input -> amp placed as desired in HD500 signal path -> FX Loop placed post-amp in HD500 -> HD500 FX Send -> Flashback -> HD500 FX Return -> remaining HD500 signal path -> HD500 output -> ........
