Looper setup
bshaw92
So I was looking through and didn't see specifics, but may have not searched correctly. If its already up please point me to it.
I have a looper in each preset. When I start a loop in a preset and want to switch to another amp preset the looper stops. What do I need to do to allow the looper to function using various presets?
No blocks continue playing across presets, including the looper. They do continue across snapshots, which is one of the very cool things snapshots give you.
EDIT: Oops, no. Shouldn't talk about stuff I've never used. See next post.
The looper can indeed continue playing across presets. From page 12 of the Helix Owner's Manual:
IMPORTANT! You may change presets while looping, but loop playback will stop unless the preset you select includes the same type of looper block (mono or stereo) on the same path (1 or 2) and is assigned to a footswitch.
