mikeebruno Posted September 25, 2016 Share Posted September 25, 2016 3 times now I have had an unexpected big buzz during live Performance. Sounds like a boat horn Everyone in the theatre was laying down flat ! And it won't go away till I step on the tuner/mute. So here is the set up: Wire less line 6 Into hd500x Direct Line out from xlr L and R. Happened 3 times on a patch that has 2 amps overdriven tones. Not the same patch Happened with hd500 two times and changed it to the brand new hd500x and happened again last night. Both with there respective power supply. I love what I can do with this but I might have to get something else. Can somebody had to resolve this problem? Thanks Quote Link to comment Share on other sites More sharing options...
mrcleenmrcleen Posted September 25, 2016 Share Posted September 25, 2016 Sounds like the issue might be with the wireless or the guitar if you had the problem on both the hd500 and the hd500x. I'd start with eliminating the wireless first. If it continues try a different guitar. Quote Link to comment Share on other sites More sharing options...
mikeebruno Posted September 25, 2016 Author Share Posted September 25, 2016 Thanks Mrcleen. I thought also. But ... Never happened when ploged in the DT amp. ( always with the wireless) And the buzz goes away when I unplug and replug the hd500. Quote Link to comment Share on other sites More sharing options...
bjnette Posted September 25, 2016 Share Posted September 25, 2016 Man that must be embarrassing. If it is different patches on two different HDs then certainly the wireless would be a contender. (battery power loss would be my guess) Otherwise check for too high a level in the patch for internal digital clipping. The trick is to somehow reproduce the noise in private and isolate the cause. Good luck Quote Link to comment Share on other sites More sharing options...
mikeebruno Posted September 26, 2016 Author Share Posted September 26, 2016 Thanks Urghanico! Yes this is the closest solution as I guess your right. But I'm pretty sure that my firm ware is updated to the latest. I will check for sure. First time this appeared is in 2014 with a much older firmware. Happened this summer and this weekend with the latest I'm pretty sure. Thanks. Quote Link to comment Share on other sites More sharing options...
