How to get the AXE tone on high gain:
arislaf
Simply, pick up your fav amp,  on the cab block (if stock) cut bellow 90hz and above 8000, then put a parametric after the cab, with mid freq at 4000, set q at minimum, and cut around 3 to 4 db. After, set bass at 130hz, and with a narrow q around 8.3 cut about 3.5 db.
