broker2 Posted August 30, 2013 Share Posted August 30, 2013 does anyone know what the distance between the strings and the pickups should be on the jtv69 variax.I would like to check mine to make sure that i have the right distance.thank you for your help. cal Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 30, 2013 Share Posted August 30, 2013 If you don't really use the Mag pickups, it may improve the sustain and tone to have them further away from the strings. Mine are about 3/16" from the bottom of the strings. Quote Link to comment Share on other sites More sharing options...
johnnyayyy Posted August 30, 2013 Share Posted August 30, 2013 does anyone know what the distance between the strings and the pickups should be on the jtv69 variax.I would like to check mine to make sure that i have the right distance.thank you for your help. cal 1/4" is standard, if they are too close to the strings L6 tech says it may cause warbling sounds in the modeling. Quote Link to comment Share on other sites More sharing options...
broker2 Posted August 30, 2013 Author Share Posted August 30, 2013 thanks guys. Quote Link to comment Share on other sites More sharing options...
