Helix, Tubemeister and 4CM with MIDI control
Anim8me2
So here is my issue.
I have my Helix going into the Tubemeister  via 4 cable method and I am using MIDI to switch channel on Snapshots
So I can have Snap 1 on the clean channel but I can switch between Helix amps and the HK preamp with a foot switch.
I do the same with each snap shot so I have one for crunch and one for lead channels. The midi assignments are applied to the first instant slot in the command center.
My problem is if I switch presets (even a similar 4CM preset) the Tubemeister Effects loop is shutting off until I press one of the Snapshots.
Shouldn't the midi command be sent automatically upon loading the preset?
Hmmm...taking a shot in the dark here:   Are the H&K programs saved with the FX loop off?  Perhaps Helix is sending the CC to turn the loop on just before the program change is sent, which is instantly turning the loop on and off.
One of the first things I checked.
I did solve it. After doing a reset I had neglected to review the default settings. The MIDI settings had gone back to default so the Helix was sending a PC MIDI command that was shutting off the FX loop every time any MIDI command was being triggered.
