millertime802 Posted November 20, 2016 Share Posted November 20, 2016 I just received a new Sonic Port VX and have used it several times on my IPhone. Downloaded and am using the Mobile POD app. Last time I used my Sonic Port it worked perfectly, but this time, I have a latency problem that won't go away. My neighbor, using all his plug ins, has the same problem. I'm not recording. He plugged in Sonic Port in and it works perfectly. Any idea why I'm having a latency problem? I switched the direct monitoring swich to both of its settings.... didn't correct anything. Thanks Brad Quote Link to comment Share on other sites More sharing options...
NBell Posted November 23, 2016 Share Posted November 23, 2016 Hi Brad, Have you tried adjusted the the Buffer Size in the settings of Mobile POD? I recommend a lower buffer rate to take care of the Latency. Also make sure certain apps (i.e. Facebook) are closed to ensure you're getting the most CPU from your iPhone. Please let us know if this helps. Quote Link to comment Share on other sites More sharing options...
