sqitso Posted December 4, 2016 Share Posted December 4, 2016 I'm very new to Pod Farm. I recently moved into a 100 year old home that is a historical marker. I am forbidden from doing any modifications to the house like sound proofing and such. The room I record in is all wood. I have done as much as I could to try and soften things up. Put in a throw rug. Long curtains. Even have some sound proofing on some stands. It helps a little but the room is still live as Hell. There is echo in everything I record. Not as bad as a preacher in a church, but it's still noticeable. Can someone tell me a nice basic setting I can use in Pod Farm to get me started in the right direction? I usually use a compressor, and clipper for my podcasts.. but I can't seem to get the echo reduced. Don't even know if it is possible. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted December 6, 2016 Share Posted December 6, 2016 Are you sure the 'echo' is natural reverb from the room? The simple solution would be to construct some free-standing bass traps (4" rockwool in frames) that you can use as movable gobos to block reflections. Quote Link to comment Share on other sites More sharing options...
sqitso Posted December 15, 2016 Author Share Posted December 15, 2016 Thanks for the reply. Yea I have been looking for a viable solution. When I bought the house I agreed to let tours go on in the house occasionally. So I cant disrupt too much. Standing stuff needs to be easily storable. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted December 15, 2016 Share Posted December 15, 2016 Do a search on youtube for DIY bass traps. You can make them 4" thick x 2'x4', with rockwool insulation, covered in any 'breathable' cloth (I've used burlap and thin cotton sheeting. You can make 'feet' for them so they stand by themselves, or hang from the walls on hooks, so easy to store away when not in use. You'll never be able to successfully remove the room reverb in PodFarm (or using any DAW plug-ins), have to stop them from being recorded. What microphone are you using? Using a dynamic mic might help if you are using a condenser mic now. You could also look at a 'reflection filter' (the sE brand is recommended by others) like this one: https://www.sweetwater.com/store/detail/Reflexion but you should still have some kind of absorbing material behind you. For the cost of one of these reflection filters you can build 4-8 bass traps! Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 15, 2016 Share Posted December 15, 2016 In the "band room" we've used a roll of carpet padding and unraveled it betwixt two PA poles (not the best but it was cheap and helped). Walls and floors are the easy parts to try and knock down "the bounce". Heated garage? or is that a regulated "historic" too. TBH the drum shield help my hearing the best. We set a huge furniture blanket up behind to help knock that down. Quote Link to comment Share on other sites More sharing options...
