MIDI/tempo & clock
steven7todd
I have a sequencer that I've used historically to send MIDI signal to guitar pedals (digital delays and the like) to set the tempo on the delays to be in conjunction with the sequencer. This was the first feature I looked into when messing around with a Helix for the first time last night and I found that I was unable to send from my sequencer into the Helix and it looks like it's on account of there being no MIDI clock feature. Do you suppose this is because the Helix is designed to the master, not the slave?
Also of note, the Helix is supposed to currently receive a MIDI CC command to set tempo via a "Tap Tempo" feature. This would allow you to send a fixed tempo to the Helix and have it set its tempo accordingly.However, the feature isn't working correctly, and Line 6 has mentioned they will fix it in the future. After that bug is fixed and MIDI clock support is added, we should have some good stuff available for MIDI synching.
