Tones2 Posted December 7, 2016 Share Posted December 7, 2016 In the old Spider IV amps, the editor used to have a switchable volume boost that you could put at the end of the effects chain that could be assigned to a footswitch to boost volume for solos. I don't see that anywhere in the Spider V editor. Does it have this? Quote Link to comment Share on other sites More sharing options...
deadlocked Posted December 12, 2016 Share Posted December 12, 2016 In the old Spider IV amps, the editor used to have a switchable volume boost that you could put at the end of the effects chain that could be assigned to a footswitch to boost volume for solos. I don't see that anywhere in the Spider V editor. Does it have this? There is a "Boost+EQ" effect that you can set post-amp. If you set everything except "Gain" to 50% it will be pretty much transparent. You can use "Gain" to set the amount of boost (in dB) that you want. You can then assign the effect block to a foot switch, to give you a solo boost. Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted December 12, 2016 Share Posted December 12, 2016 You can also use the compressor to achieve an overall volume boost by setting the threshold to a high value (lower number) and the gain will adjust the amount of boost. The compressor is footswitch 1 by default on the FBV3 or Function 1on the FBV mkII (where the volume boost was for the Spider IV) Quote Link to comment Share on other sites More sharing options...
