nd_mustang Posted December 14, 2016 Share Posted December 14, 2016 I have just two inputs: 6 - XLR from Helix to M20d 3mm plug - MP3's (for practice) The MP3's play in stereo I can only hear me in the Right L2t speaker, despite the fact I have my setting as Center It shows 5/6 taken up with the one XLR connection as well. Is that normal? Can anyone help? Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted December 14, 2016 Share Posted December 14, 2016 Sounds like you've inadvertently created a stereo pair between 5/6 If you then only plug into channel 6, you're only routing to the right Go onto the "SETUP" screen, tap the guitar input on screen and look in the upper left corner of the stage area, where there should be a stereo pairing control which should allow you to unlink the two. 1 Quote Link to comment Share on other sites More sharing options...
nd_mustang Posted December 15, 2016 Author Share Posted December 15, 2016 Thanks! I'll give that a try! Quote Link to comment Share on other sites More sharing options...
nd_mustang Posted December 15, 2016 Author Share Posted December 15, 2016 So, I don't see what you're saying as far as splitting the pair up at all. No matter what I do it shows 5/6 pair for the Helix - I'm using the "HD500" preset that they have and renaming it to Helix. Thoughts? Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted December 15, 2016 Share Posted December 15, 2016 POD HD500 is a stereo preset To use it, you need to run 2 cables from the HD500 to the M20d. Plug L into 5 Plug R into 6 The HD500 preset is not available as a mono preset To run it mono, you'll need to unplug, delete the input then plug back in to just 5.and use the Guitar Modeler preset 1 Quote Link to comment Share on other sites More sharing options...
nd_mustang Posted December 15, 2016 Author Share Posted December 15, 2016 Ahhh, ok. And that will make the mono signal "stereo" then? I don't need a stereo guitar, but I want it to output to both speakers. :) Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted December 15, 2016 Share Posted December 15, 2016 A mono preset is routed to both L and R main outs an the pan control governs how much each side gets. It's still a mono signal, just fed to both sides. A stereo preset anticipates stereo inputs (ie 2 channels) BUT the pair of inputs are linked within the M20 to a single channel control. In this setup, the pan control governs how much of each of the two channels is fed to L&R respectively. This is a stereo signal and only the L input (5 in your case) will go to the L side, and the right input (6 in your case) will go to the right side. Pan is adjusting the relative level of those two signals against each other. Your HD500 has a stereo output because, I assume, many of the inbuilt effects output in true stereo. Quote Link to comment Share on other sites More sharing options...
nd_mustang Posted December 15, 2016 Author Share Posted December 15, 2016 Ok, you were right. I fed it to a mono input and all was good! Quote Link to comment Share on other sites More sharing options...
