hideout Posted December 17, 2016 Share Posted December 17, 2016 Is it my imagination or was there mention of being able to change the color of the Footswitch LEDs in 2.10? if there was, I can't find any thread on it. Thanks. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 17, 2016 Share Posted December 17, 2016 You have been able to change the Footswitch color for stomps from the 'Bypass Assign' tab/screen of the Editor for a while now or directly from the Helix using the Bypass Assign --> Customize or the Command Center --> Customize screens but you can now change Snapshot colors as well but only from the Helix device, not the Editor. The instructions were under the release notes for the 2.10 'Flash Memory' (not Helix app) download.From the 2.10 Flash Memory release notes:Snapshot footswitch LED color—You can now choose a color for each snapshot footswitch. Press the PRESETS knob and then Knob 6 (Rename Snapshot). Turn knob 5 (LED Color) to select the desired color. “Auto Color†is the default red. NOTE: There is currently no way to set snapshot footswitch color from the Helix application. Quote Link to comment Share on other sites More sharing options...
hideout Posted December 17, 2016 Author Share Posted December 17, 2016 You've done it again, HO. Thank you, sir! Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 18, 2016 Share Posted December 18, 2016 You've done it again, HO. Thank you, sir! Cheers :) Quote Link to comment Share on other sites More sharing options...
jshimkoski Posted April 7, 2017 Share Posted April 7, 2017 For future reference, this information can be found on Helix Help, here: https://helixhelp.com/2017/04/07/tip-change-snapshot-led-color/ You can also do search for this tip in the search box on any page on Helix Help as well. Quote Link to comment Share on other sites More sharing options...
