chrisko97 0 Posted December 27, 2016 I own a line 6 spider iv 15 combo, im thinking of bying a Boss Gt-10.Does the gt-10 is compatible with the amp and how i connect it? (Sorry for bad english) Quote Share this post Link to post Share on other sites
fflbrgst 1,852 Posted December 27, 2016 Boss GT-10 is a fairly old (discontinued) model, maybe you mean GT-100? Either way, these are external (stomp-box type) effects processors. You would plug your guitar into it, then the output of it to the input of the amp. Most likely you would keep the amp on 'Clean' setting. Quote Share this post Link to post Share on other sites
dwitek 0 Posted May 22, 2017 It also depends on if you need multiple processors that are mutually exclusive on the amp. For instance, on my 75 I like to have distortion and compression on at the same time but only one or the other is allowed. So, I run the compression on the amp and use a Tube Screamer for distortion. Keep your amp fairly clean and add the other effects you need like trem or chorus.. Quote Share this post Link to post Share on other sites
