massimilianof
how create "good" Distortion tone in Line
Hello
Last week I bought aAmplifi TT
I encountered a problem in reproducing sounds distorted with headphones or entering directly into a mixer or Hi-Fi: distortion look like a "mosquito" and are not true to distortion reproduced by amps + effects pedals.
A friend of mine, owner of a
pod hd500x , explained to me that he had encountered the same problem with the Pod and solved it by acting on an output adjustment (line or amp) on a particular menu of Pod.
I have looked for in the menu of AmplifiTT but i have not found it.
There is the possibility to correct this problem nell'Amplifi TT?
Does your tone have an Amp Cab in it? if it is missing, any sounds with distortion will sound like a mosquito swarm. If you have, and the cab is the appropriate one for the amp (sometimes, mismatched cabs also give you a buzzfest), then try to turn on the Parametric post-EQ on the tone and reduce the hi-freq shelf by -3 db at 5000Hz or higher... you can toy with the frequency until it you get as close as you can to your goal and then go up/down with the db adjustment (keep it in the negative range, though) until it sounds best to you.
