naruto177 Posted September 6, 2013 Share Posted September 6, 2013 I want to have a pedal I can use that would give me those mids to cut through for a solo but I dont know how much I can raise volume without being over power. I have a boost pedal about 75% time on for my lead playing at church for like Lincoln Brewster music but when it goes to a solo I want to push on something to make it more present. What would you recommend? I got one spot on my pod fx for a pedal Thank you! Quote Link to comment Share on other sites More sharing options...
parkinthepark Posted September 6, 2013 Share Posted September 6, 2013 For a clean mid boost, I like the Q-Filter set for band-pass, with a fairly wide Q. This will give you plenty of cut without a lot of extra db's. 1 Quote Link to comment Share on other sites More sharing options...
naruto177 Posted September 6, 2013 Author Share Posted September 6, 2013 Im not really fimiliar with messing with the EQ but like maybe used another pedal with like certian setting I guess would help or like set your volume pedal at __% and when you push it up it goes to 100% stuff like that. My mind in the EQ stuff is very small and not really fimiliar adjusting my pedals for better sound so having the individual knob positions would help Thanks! Quote Link to comment Share on other sites More sharing options...
ftuller Posted September 7, 2013 Share Posted September 7, 2013 I use the tube comp with thresh at 100 and level between 12-17 as a boost. My base chain order is volume pedal, tube comp, tube screamer, digital delay, amp. 2 Quote Link to comment Share on other sites More sharing options...
deguello Posted September 10, 2013 Share Posted September 10, 2013 Can't you run a patch cable from FX Send to FX Return, assign the FX Block to the first position and when activated it gives a nice clean boost to the signal? Quote Link to comment Share on other sites More sharing options...
bjnette Posted September 11, 2013 Share Posted September 11, 2013 This is a simple DIY you can make and can use on any patch. You just disengage the volume taper and your at full volume. http://www.premierguitar.com/articles/19549-state-of-the-stomp-build-a-preset-volume-box Quote Link to comment Share on other sites More sharing options...
