m20d recording issue... really weird one
Hey!
First of all, thanks for reading and thanks in advance for your help.
I've been using a Stagescape m20d to monitor in studio rehearsals for a while now, and I've had no problems with it.
Recently I decided to start recording said rehearsals into a USB flashdrive in order to review the music we're writing and make adjustments. I don't need to work on these recordings much, I just import them to cubase on my PC, where I can listen to them.
Worked well for the first 3 days and then it started to produce slowed down recordings... how much they are slowed down varies, sometimes it's barely noticeable and sometimes the recording is well over 10bpm slower than recorded. Any idea why this may be happening?
Thanks
I have never seen that.
We regularly record rehearsals when we are in the loud room using the M20d, but I use an SD Card to record.
If you haven't accidentally jogged the playback speed in Cubase then you might try using an SD Card - I reserve the USB port for Wifi
 I checked the playback speed in cubase and it works fine. I'll try using an SD Card :D thanks for the idea.
