alessiovenaria Posted September 12, 2013 Share Posted September 12, 2013 Hi! I'm using Pod xt with Guitar Rig but i have some latency (30-40ms). Can I reduce latency? I have less latency if I use WASAPI driver than ASIO. it's normal??? (sorry for my English) Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 12, 2013 Share Posted September 12, 2013 What DAW are you using? Are you trying to use the PODxt as just the interface or are you wanting to use it's tones and effects with Guitar Rig? Quote Link to comment Share on other sites More sharing options...
alessiovenaria Posted September 12, 2013 Author Share Posted September 12, 2013 What DAW are you using? Are you trying to use the PODxt as just the interface or are you wanting to use it's tones and effects with Guitar Rig? I want use podxt only as audio interface Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 16, 2013 Share Posted September 16, 2013 Depending on your DAW and computer, it's pretty common to have latency when monitoring vst's in realtime. I would use the Line6 ASIO driver, and from the Line6 Audio-MIDI device control panel have the PODxt send unprocessed but monitor the processed. Dial in a tone close to what you are going for in GR and then add GR to the dry track post processing. Quote Link to comment Share on other sites More sharing options...
