Lefthand Players Take Alook Here
Hallo Lefthand Players
After playing on all jtv guitars and some thinking I got me a jtv89
Why, cause you can play higher up on neck
To make it work as a lefthand guitar you have to switch pietzo wires on a small white socket connected to motherboard
2 gray wires from piezomics with 4 small wires on each, black, red, white and yellow
On white socket there is 8 small locking flips and under them 8 metal shoes connected to each wire
Use a very small flat tool
Gently place it between locking flip and metal shoe and bend very carefully,  just so much you can pull out wire with metal shoe
Switch left black wire with right black wire, switch left red wire with right red wire and so on …..
Insert them, they lock themselves
It work to play by turnaround nut, but off cuors you have to make a new
If you have power supply from your older varaix, it works with jtv
Now you are ready to Rooooock
With new workbench HD it sound sooooo gooood
PS
Open attached file to see it with pictures.
PaulSky
HOW TO DO RIGHT TO LEFTHAND 01.doc
