vfriel Posted September 15, 2013 Share Posted September 15, 2013 Well after 3 years of faithful service I just discovered that the Model Select knob on my M( does not function properly when it's pushed. Either I have to push it numerous times or from specific angle to get it to change an FX type. Fortunately I have already had my patches in place but this looks like a problem that is only going to get worse. Anyone here experienced a similar problem? Anyone here know of a fix? Yes, I opened a ticket with Line 6. Quote Link to comment Share on other sites More sharing options...
doncelestion Posted November 7, 2013 Share Posted November 7, 2013 Pull the knob off and put it back on - problem solved Quote Link to comment Share on other sites More sharing options...
scormier Posted November 9, 2013 Share Posted November 9, 2013 I had the same issue, as DonCelestion said pull it off (also give it a good shot with a can or compressed air, and or a little circuit cleaner) and then push it back on. Some times dust and dirt can get stuck in there. Quote Link to comment Share on other sites More sharing options...
wa2gls Posted December 14, 2013 Share Posted December 14, 2013 pull off knob... put a small pinch of paper towel into the knob and reinstall... Problem is that the knob can't go down far enough before it bottoms out on sheet metal cover..need to raise the knob to achieve full length of travel on pot... This should work... just bought 2 used units having this problem...... did the above.... everything now wonderful BEST REGARDS, Jim B Quote Link to comment Share on other sites More sharing options...
jqpaxton Posted December 24, 2020 Share Posted December 24, 2020 Seven years later this post was a lifesaver for me today. It came up when I googled "line 6 m9 model select button not working." The suggestion in wa2gls's post above saved Christmas. Thanks! Quote Link to comment Share on other sites More sharing options...
