Jackson_H Posted April 12, 2017 Share Posted April 12, 2017 Hello all. Well, I got the issue resolved with the Wah and now have another problem. When I power up the POD everything comes up and works normally. I'll see the Channel and bank in the POD readout, and the floorboard's corresponding Channel LED is lit, and the LED readout shows the correct bank. If I then try to Bank up or Bank down, the channel LED goes out on the floor board, the Channed disappears from the POD readout, the floorboard shows the new bank number, but the pod remains on whatever bank it was on, and nothing really changed. If I change channels from the floor board, everything goes back to normal, but chokes again if I try to Bank up or down. Everything else seems to working fine. This all worked prior to the Wah repair. Any ideas what might be going on??? Quote Link to comment Share on other sites More sharing options...
Jackson_H Posted May 8, 2017 Author Share Posted May 8, 2017 Chalk this one up to operator error. I had not used the foot switch enough to be totally familiar with it's workings, and didn't recall you have to select the Bank first, then select the channel... you can't just bank up or down without selecting a channel. Quote Link to comment Share on other sites More sharing options...
