Keeps switching on to edit mode at random
cman83
Whilst using any patch, the system keeps switching onto edit mode without me touching it and then switching off the amp/cab too.  very frustratiing when simply playing along.   Its almost as if someone is hitting the edit button repeatedly.  I thought the button might have it a dodgy contact that is causing this or maybe its a bug.
Any advice?
thanks
I think your first guess is correct, the switch is dodgy. You can try disassembling the unit and cleaning the switch with some DeOxit contact cleaner. That should help resolve the problem for a while. If needs be a Service Center can take a look at it and replace any bad switches.
