geelongcats Posted May 20, 2017 Share Posted May 20, 2017 I bought the pod xt live in 2004. I never really used it to its potential but I've started playing again. Line 6 won't let me rigister it to be able to use the monkey program. Is there any way around it besides buying the helix? Many thanks. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 20, 2017 Share Posted May 20, 2017 You don't have to have it registered to use Monkey. You can simply hit cancel when it asks you to register. At this point, registering probably isn't going to do any good for you or Line 6. Quote Link to comment Share on other sites More sharing options...
geelongcats Posted May 20, 2017 Author Share Posted May 20, 2017 Thanks mate, I worked it out. My next question is I remeber you used to be able to dial in your settings/tones/effects via a computer connected to the POD. I assume it was using POD farm but it won't let me run it because of driver incompatibility. Do you know if there's a way around it? Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 20, 2017 Share Posted May 20, 2017 There were actually two different editors for the XTL - Line 6 Edit and Gearbox. Gearbox is the newer of the two, so I'd start there. Quote Link to comment Share on other sites More sharing options...
Mike357mm Posted June 25, 2017 Share Posted June 25, 2017 Is their another way to get line6 edit or gear box for the Podxt live, I have try ed and all I get is no match, and yes it is registered, the. Editor for my HD500 works great, But I need a editor for me Podxt Live .Can any one help....? Quote Link to comment Share on other sites More sharing options...
BillBee Posted June 26, 2017 Share Posted June 26, 2017 When you say "no match" I guess you mean for your OS. If so, choose one from an older OS as new as possible. There has not been anything upgraded for L6 Edit or GB for a long time. Quote Link to comment Share on other sites More sharing options...
