Flextone II HD head is not recognized by Edit software
Hi mates:
anyone can help me with this issue, pls?
I got mu FT II HD connected to my computer via MIDI (in & out) to a USB port. I run the Edit software but this does not recognize my amp. I select my amp manually but it seems that it is not fully recognized, and I do doubt that I could load or edit any effect or edit any bank.
I would like if any one can explain me if I do something wrong. Thank you.
The usual problem is the midi/usb adapter. If you are trying to use an ebay $2 special then that is probably the issue. I've used an M-Audio Uno many times with the Flexy so try one of those. The cheap ones IIRC cannot send a large enough chunk of data. Sometimes reversing the In/Out works if you already have an Uno - why who knows but its how mine has worked with numerous L6 devices (flex, duoverb, pods).
