Phil_B Posted June 27, 2017 Share Posted June 27, 2017 Hi All, I have a shuriken and helix (all with the latest firmware installed) I notice that when i’m trying to select the preset model for Variax on the Helix (under input settings for each preset) the models names listed dont match up to the Shuriken model names - I assume this is becasue the Helix stores the JVT models rather than the Shuriken model names. Example: User I (1-5) is the first set available on the Shuriken, and this matches up fine on the Helix. The next set on the Shuriken is User II (1-5) but is labelled T-Model (1-5) on the Helix. And the rest of the names dont match up either. This is very confusing when trying to select the appropriate User model on the Helix to force for each patch becasue the names dont match up and I end up having to count from the first and scroll through one by one. Is there a solution, or is this a known issue? Cheers, Phil. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted June 27, 2017 Share Posted June 27, 2017 No solution - the Bank Names are the defaults for a Variax Standard/JTV and match the printing on the knob. I hadn't looked at the Shuriken banks before but they are very different and I can see why that is confusing as Tele, Spank and Lester are completely offset. The solution would be enhancement of Helix to detect Shuriken and use the correct names - ask for this on Ideascale: https://line6.ideascale.com/ Personally I rarely use the knobs to set the required model - I find it much easier to just move the controls on the guitar and Helix follows what you are doing. Quote Link to comment Share on other sites More sharing options...
katerlouis Posted September 7, 2017 Share Posted September 7, 2017 I find this also very bothersome- There is an ideaScale for this: https://line6.ideascale.com/a/idea-v2/901664 Vote it up, fellahs! Quote Link to comment Share on other sites More sharing options...
Phil_B Posted September 7, 2017 Author Share Posted September 7, 2017 I find this also very bothersome- There is an ideaScale for this: https://line6.ideascale.com/a/idea-v2/901664 Vote it up, fellahs! A chap who works for Line6 said on a Facebook forum that this will be addressed in the next update. Fingers crossed. 1 Quote Link to comment Share on other sites More sharing options...
