Rokaround Posted May 5, 2013 Share Posted May 5, 2013 Is it possible to transmit with 1 Belt pack and recieve with 2 G90 rack units the same signal going in to 2 seperate amplifiers ? IO have signal ground loops happening am using 2Mixes for My guitar do not want to use a Mixer thoughts on this subject? Thanks in advance Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 5, 2013 Share Posted May 5, 2013 Yes ... you can assign a transmitter to as many receivers as you like (surround 7.1 if you wish :) ) Quote Link to comment Share on other sites More sharing options...
rhodes73 Posted May 20, 2014 Share Posted May 20, 2014 why don't you just use the tune output to cable to your other amp Quote Link to comment Share on other sites More sharing options...
eklynx Posted May 20, 2014 Share Posted May 20, 2014 One other possibility: I know the G50 has a 'main out' (mutable via belt pack) and an "aux/tuner out" (always on, even when muted). If the G90 has similar and you don't care about belt pack muting you might be able to just use those two outs with only one receiver. Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 20, 2014 Share Posted May 20, 2014 You could use the tuner out. It is identical to the main output but buffered. But you still will have a common ground connection. If that is your main problem you'll need a transformer isolated DI box. OTOH two separate receivers would also fix the problem without dragging long cables. Quote Link to comment Share on other sites More sharing options...
