DBCrocky Posted July 12, 2017 Share Posted July 12, 2017 I just got Helix LT and have been playing with it with my JTVariax. In setting up my rig, I wanted a master volume, so I put a Volume Pedal block in each patch where it should be (before delay and reverb), and set the EXP Pedal 2 to Global, so once I set the volume pedal, it carries over from patch to patch. This is good. But what would be better is if I could do the same thing with the Variax volume knob. You can get so much more control with the guitar's volume knob than you can with a pedal. If I set a Volume Pedal block to be controlled by the Variax Volume, one I go to a patch the pedal position parameter returns to the saved position, and I have to tweak the knob. Is there a Global setting for the Variax Volume control, and if not, could there be? P.S. In order for this to work, there would have to be a way to disengage the volume knob from controlling the variax output volume of the guitar. Quote Link to comment Share on other sites More sharing options...
DBCrocky Posted July 13, 2017 Author Share Posted July 13, 2017 Ok, found out how to disengage the volume/tone knobs, it is the Variax Lock Controls function. So all we need is a Global Parameter for the Volume (and/or Tone) knob just like for the Exp Pedals, and this would work great! Quote Link to comment Share on other sites More sharing options...
