Sign in to follow this
christian30
spider V and Qbase
Hi I have problems to connect my spider V with Qbase in my PC . Anyone could help me please . Is there anywhere a video or a topo to explain the way to connect it ?
Thanks for your help so needed !
Did you download the drivers? I assume you have Windows PC.
http://line6.com/software/index.html
Restart the computer once the drivers are installed.
Install Cubase Software. Connect the Spider via USB to your computer.
Run Cubase and start a new project.
To record, select the Spider V as your audio input source for any track you want to record to.
Arm the track and then record. Audio should stream and start recording.
Cubase has Youtube videos with great demos. Just know that Spider V is your interface (they'll use their own)
still no result ... do I have to choose audio pist or midi or instrument .
When I play, i can see a signal come in because I can see moves on the diagram at the bottom . But when I want to listen what I've just recorded, no sound ...
