fr0sty Posted August 23, 2017 Share Posted August 23, 2017 I have some patches I like that are built around an amp/cab combo. I would like to try the same amp settings with some of my impulse responses without creating a new amp head patch with the same settings. Is there a way to turn off the cab? I can't seem to find a way to do that. Quote Link to comment Share on other sites More sharing options...
kdog Posted August 23, 2017 Share Posted August 23, 2017 If you hover above the cab icon there is 'power' symbol that can toggle it off. It is also present on the settings screen where you select the mic and such to bypass the cab. Quote Link to comment Share on other sites More sharing options...
twpmeister Posted August 24, 2017 Share Posted August 24, 2017 Kdog that only helps if you are using separate amp and cab blocks, from op's question I assume he's talking about a combo block. On helix edit if you selected the head of the same amp as you already had as a combo it would retain any amp settings already tweaked, you could then simply add an IR block. I haven't experimented to see if native likewise keeps the settings if you swap between combo and head. 1 Quote Link to comment Share on other sites More sharing options...
fr0sty Posted August 24, 2017 Author Share Posted August 24, 2017 Yes, that's the exact issue. I used the amp/combo block but when I switch the block to a head block, it changes all my settings. Not a huge deal, but it's a bit of a mind shift from pod farm, which I'm used to. I would be nice though to be able to do that. Kdog that only helps if you are using separate amp and cab blocks, from op's question I assume he's talking about a combo block. On helix edit if you selected the head of the same amp as you already had as a combo it would retain any amp settings already tweaked, you could then simply add an IR block. I haven't experimented to see if native likewise keeps the settings if you swap between combo and head. Quote Link to comment Share on other sites More sharing options...
twpmeister Posted August 24, 2017 Share Posted August 24, 2017 Surprising they didn't bring that over from helix edit, was useful. Quote Link to comment Share on other sites More sharing options...
fr0sty Posted August 24, 2017 Author Share Posted August 24, 2017 Yea, and as long as we're talking about the editor it would be great to be able to drag presets and create dual amp tones from an existing patch. I can drag a single saved tone over, but it seemed like I should be able to drag another tone over and make a dual channel patch. I'm still getting used to how helix editor routes, so maybe there's already an easier but different way to accomplish that. Quote Link to comment Share on other sites More sharing options...
kdog Posted August 24, 2017 Share Posted August 24, 2017 Kdog that only helps if you are using separate amp and cab blocks, from op's question I assume he's talking about a combo block. Darn, yes, you are correct, I misread the OP. Thanks for the correction. Quote Link to comment Share on other sites More sharing options...
