toddfugere Posted August 24, 2017 Share Posted August 24, 2017 I've been having an issue with my Pod HD Pro X and reamping. It seems that whenever I reamp I get a ghost tone, almost like a heavy reverb or feedback loop. However, while actually playing the guitar everything sounds perfect, no issue. It's only during the reamping. I've tried multiple setups for reamping. I used this setup https://www.youtube.com/watch?v=S_mYnOX0XNs. I've also connected SPDIF out from Scarlett 6i6 into Pod and back out from POD into Scarlett SPDIF. I've also connected Scarlett Line outputs 3 & 4 to POD. Seems that no matter how I do it, still get the feedback loop. I've also tried adjusting settings in the Line 6 Audio-Midi Devices. I've tried different patches, different DI signals, tweaking settings in pod, inputs settings, DAW monitoring, etc. I have recently purchased new instrument cables and SPDIF cables. Nothing seems to work. I also learned that having POD HD Pro x Edit closed makes it a little better as well as removing the USB cable to POD during reamp. But it's still a huge issue. Seems like it's not so noticeable on clean tones, but whenever there is anything with any gain involved it's very apparent. Especially on quick stop and start passages. I have an attached a sound clip. Anyone else experience anything like this? Feedback Loop.mp3 Quote Link to comment Share on other sites More sharing options...
joel_brown Posted August 24, 2017 Share Posted August 24, 2017 Sounds like a DAW monitoring issue or it's going to a channel you don't know about that's being monitored. I would try disconnecting some of your connections and see if that helps narrow down the problem. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted August 25, 2017 Share Posted August 25, 2017 I agree it's most likely in an input monitoring/looping issue. It may be in the DAW and/or in the Scarlett. Quote Link to comment Share on other sites More sharing options...
