HerbertOehlers Posted September 28, 2013 Share Posted September 28, 2013 My Variax 700 is not producing any sound when I connect it thru the1/4"plug, I checked the batteries they are ok with 9.5 volts...If I use my variax 700 hru VDI it works. What else could be the problem? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted September 29, 2013 Share Posted September 29, 2013 Try the 1/4 inch plug while powered through the VDI. If that works then it's probably your battery connection between the battery and the main board. Should not be too hard to fix. The main board is healthy if your 700 plays through the VDI. Quote Link to comment Share on other sites More sharing options...
HerbertOehlers Posted September 29, 2013 Author Share Posted September 29, 2013 I powered the Variax 700 thru the VDI and plug into the amp via the 1/4" jacks and it works...Thanks for the tip. I could be that the doide is broken, because I measured the power and notices that only after the diode the power is gone... Quote Link to comment Share on other sites More sharing options...
