satsamel Posted September 22, 2017 Share Posted September 22, 2017 Hello, I need some help. I've been trying to find the best way to record the sounds coming from the Line 6 Amplifi 150 amp. I'm trying to record a live rehearsal session and although I can mic up the amp I was wondering what would be best option. I'll be using a Focusrite as the audio interface. I want to capture the effects that the guitarist uses how can I go about doing that? The headphone jack disables the speaker when it's connected so I cannot use that for a live recording. At this point mic'ing the Line 6 Amplifi will be the better decision. I know you can connect the Amplifi to a computer using a USB cable, but that would be a direct recording and I want to keep it as a live recording. Plus I'll be using an audio interface via USB. It would be great if Line 6 added some type of direct out stereo jack and allow the amp to continue working through the speaker for recording and live performance. I need some helpful advice. Thanks, Quote Link to comment Share on other sites More sharing options...
NBell Posted September 27, 2017 Share Posted September 27, 2017 Hi Satsamel, I recommend recording via USB. If you were to record from any output jack like the headphone jack or a hypothetical dedicated output jack would yield the same results as recording via USB, only difference is that USB offers a higher quality of recording. Depending on your recording set up, to capture that 'live' essence I recommend throwing up some room mics, if you don't have enough bleed from drum mics or any other instruments. Quote Link to comment Share on other sites More sharing options...
MGDASKOS Posted February 1, 2019 Share Posted February 1, 2019 Hello , I have just purchased the LINE6 AMPLIFI 150 and I have the same problem . My daw uses the driver of my console (PRESONUS STUDIO LIVE 24 series 3) and if I use line6 driver the daw "sees" only 2 inputs and outputs from the AMPLIFI 150. Using a mic is not an option because of the bleed of the drums and other amps and headphone output mutes the amp. I think that an AMP OUT connection is a necessity in every guitar amp and LINE6 should take care of it in every amp model. Quote Link to comment Share on other sites More sharing options...
