Using An External Tuner
Tehzim
I tried to search the forum for this but I couldn't find anything.  If I want to use an external tuner instead of the Helix internal tuner, how do I do that?  Do have to put it before the Helix or in an FX loop?  I was under the impression there was a place to plug it in that would let you bypass the Helix tuner but use the same floor switch.  Thanks in advance.
  • Downvote 1
The easiest way would be to place your tuner before the Helix.
If you have a favorite pedal or rack tuner and wish to use it instead of the Helix tuner, connect Send 1, 2, 3, or 4 to your tuner's input and turn Knob 2 (Tuner Out) to select that Send. This way, every time you hold the TAP footswitch, Helix will automatically route the signal to your favorite tuner.
It's amazing what you can find in the Owner's Manual
