GiovanniC Posted October 1, 2013 Share Posted October 1, 2013 Hallo to everyone! I've been using Pod X3 Live for 5 years as stand alon unit directly connecte to PA with great results. After having sold my TC Electronics G-System, I would now need to use it sometimes in 4-cables method connected to my custom guitar head, Masotti X100M. I'm pretty familiar with that configuration, as I used it for several years with G-Sys. But using X3 live I'm experimenting some problems in volume levels setting. In particular, I have big volume drop when connecting the Pod to amp front end (pod fx send --> amp input): if compared with guitar directly in amp input, when I pass through Pod it seems I loose a lot of signal. I tried to compensate volume loss increasing loop send level, but when I match clean channel volume levels I notice that crunch and lead channels distortion level increases. So if I turn back loop send level to match amp lead channel distortion level, when I switch to clean channel I have again clean channel volume ridicously low. On the other hand, I'm fully satisfied of the regulations of the interface between amp loop and pod: regulating loop return level and amp bypass level I exactly paired amp alone volumes, with apparently very small tone losses. Is there someone who experimented similar issues? Is there any suggested setting to overcome the problem? Note: I have set guitar pad on as with most of my guitars clip red light is almost always red! =( Thanks!! Quote Link to comment Share on other sites More sharing options...
