walker34743
foot pedal for spiderIII 150
Hi guys, have just purchased a spiderIII 150 for my 15yr old son and tried a fbv express mkI but it didn't work. Do I need the mkII and would this require a pod or work just plugged into the combo?
Thanks, Alan
Here ya go:
http://line6.com/support/page/kb/_/effects-controllers/fbv-mki-mkii-controllers/the-complete-line-6-pedal-compatibility-faq-r58
Everything and more than you ever wanted. :)
I would try a different cable (cat 5) to make sure it was the FBV that was bad (could be the port on either the amp or the fbv but usually s-not).
tested mk1 before paying. tuner worked but wah/volume stayed on volume. when tried to play, it cut the amp out. been advised from both the vender & my local music store that it needs mk2. will look through the link. thanks BillBee
FBV Express MK1(Does not have USB Port): Compatible With: Spider Valve, Spider Valve MKII, Spider II, Spider III
Your vendor and music store are wrong.
The toe switches in the FBV are pretty stiff and you have to put some weight on them (ie stand up and try). Its either the amp, cable or fbv. You can always take the amp up to the store and try one of them out with it.
