alphachoice77 Posted November 23, 2017 Share Posted November 23, 2017 Hello, is possible Presets/Patches from Pod XT Live to Pod HD 500x Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 23, 2017 Share Posted November 23, 2017 Not directly. You will need to do it manually and even then they won't sound the same because of the difference in the modeling engines. But it can be a good starting point for tweaking. To do it manually, run the Pod XT editor with the Pod connected and simultaneously run the HD500X Edit program (you don't need to HD500X connected). Manually recreate the settings in HD500X Edit and then save the HD500X presets to a folder on your computer. When done disconnect the Pod XT, connect the HD500X, and import the saved presets. Tweak as desired and then send the presets to the HD500X device. Quote Link to comment Share on other sites More sharing options...
VAX700 Posted November 29, 2017 Share Posted November 29, 2017 No. The HD Pods have newer / more advanced processors than the XT Live, so you can't import XT tones to an HD500X. It's like trying to run Pentium 1 software on a quad core i7 computer. But you can come close to recreating your XT tones: You need to replicate them effect by effect, parameter by parameter (or as close as possible) on your 500X. It takes some time but it's worth it... the patches / presets might not sound exactly the same, but in the process you may find your old tones have actually improved. Quote Link to comment Share on other sites More sharing options...
