Helix Native for Vocals and Non-Guitars
soundog
I spent a little time yesterday running some non-guitar (vocal, harp, sax, drum and keyboard) tracks through Helix Native.
To do so, use Helix as your first plug-in on the track, preferably a Mono to Stereo instance (if your track is mono). Start with a blank Helix preset with no blocks. Adjust your in and out gain to give you equal audible levels when you toggle bypass (I use -16 dB input level). Then, insert a single Helix block into your path to play around with. You can chain blocks together after you get a sense of how each effects the sound.
Since the blocks were primarily designed for guitars, not all of them seemed useful with certain instruments. But I was surprised with how effective and useful some of them were, especially if you don't have a lot of effects plug-ins (Sound Toys, etc). For example:
- a lot of the Modulations and Delays were quite useful, especially stereo versions
- I was hoping for some good rotary (Leslie) effects, but was disappointed (except for distorted versions on Hammond B-3 sounds). Rotary effects are difficult to replicate on vocals (Melda makes the best rotary plug-in I've found).
- pitch-based effects are pretty limited (you end up with chipmunk and Frankenstein on vocals, for example). I wish Line 6 would add some vocal-friendly pitch shifting (like those found in TC Helicon pedals).
- distortion (from either pedal or amp blocks) might be useful on some instruments (even vocals) for really specific effects. At least there's a lot of variety to play with.
- the reverbs are hit and miss, but some far-out verbs (like Particle Verb) are nice to have in your tool box
- wah pedals are useful for certain applications, especially keyboards
- get familiar with how to automate parameters for even more fun. Helix Native has great support for assigning parameter automation
  • 2 weeks later...
On a recent tune I did I tried using the bullhorn in native to get that scratchy/telephone vocal sound.
Long story short I ended up using the tube screamer instead. It sounded better for my application.. had all the lofi I was looking for but a much warmer, almost vinyl like vibe
