Helix as MIDI CONTROLLER FOR MIDI SCREEN
paulosousa
Hello
I have a MANSON GUITAR with MIDI touch screen, i'm not able to control the pod with the screen (it works with a KAOSS PAD or a WHAMMY DIGITEC)
anyone it's able to do that?
I want to use the touch for example instead of the pedal for the WHAMMY DIGITEC effect
Assuming the MIDI screen sends CC messages and everything is connected correctly, it should be really easy:
  1. Press and hold the knob for the parameter you wish to control. For example, if you want to control a wah, press and hold the wah block's Position parameter. Helix jumps to the Controller Assign screen.
  2. Press Knob 6 (Learn Controller) and then move your finger on the touch pad. Helix learns the MIDI CC sent. If desired, set the Min and Max values accordingly.
  3. Press HOME when finished.
