Sign in to follow this
Vagranth
Recording pure guitar tone, monitoring processed
Hello,
Is there any way to record a clean signal (without any processing, like true by-pass) from your guitar directly to your DAW while monitoring a processed signal? (For further re-amping of obtained clean signal)
Amplifi is unable to send a dry signal out while also providing an amp sound for monitoring. If you have Amplifi set to send clean unaffected signal to your DAW then that is what you will hear, unless you add any post processing/modeling in your DAW.
If I understand correctly, you should be able to do this using a plug-in such as Helix Native, etc. You turn the plug-in off and the signal is totally dry. Turn it on and you get whatever you want. What you hear in the monitor will be what ever is going on in the DAW. Dry without plaugin, wet when plugin is on. Hope this helps. Sorry if I am misunderstanding!
Create an account
Register a new account
Sign in
Sign In Now
