Helix LT One-Stomp to engage preset "next" in order of Song-Set-List
hkberlin
I own Helix Lt for 2 weeks now. Read Owners Manual. All Line 6 tutorials. Many other YT demos. Tried many things on the item. Great sounds, but no handling clues yet to my needs to follow. >>> I need professional help:
1. Putting my newly created [user presets] in wanted Order  (= the order of my band set-list for a gig, i.e. for each next song the created next Preset, totalling 20 Songs / Presets) : Qu.: what is the easiest way to get this order? side-hint: I did customize existing presets, yet have not moved them to the desired number.
2. Find a shortcut, enabling  [stomp "down"] directly leading to the next [user Preset]. Or any other [stomp] if necessary.
I would be negatively surprised, if Helix would be unable to deliver this functionality, which in my experience every serious user, who will use Helix on stage, needs.
Currently I can see only these steps being necessary:  at least three, but also four to six steps:
Assuming, I have successfully numbered / putting my [user Presets] as # 1 through # 20
1. to get # 1 > [stomp "up"] (look and see Preset 1# - #8),  > [stomp upper D]  >done, ******** 3 Steps  (looking is also 1 step :-)
2. to get # 9  >[stomp "up"] ,  > [stomp "down"], (look for #9) , > [stomp upper A] > done  ******** 4 Steps
3. to get # 18 > [stomp "up"] ,  > [stomp "down"] x 2, (look and see Preset 9# - #18),  > [stomp upper D]  >done, ******** 5 Steps
4. to get # 20 > [stomp "up"] ,  > [stomp "down"] x 3, (look and see Preset 19# - #26),  > [stomp upper B]  >done, ******** 6 Steps
I would appreciate very much a good solution tipp, otherwise I might have to return my purchase because this functionality is of essence to me.  So thank you in advance for a quick help, I am hoping for!
with regards
I did this in the past when I was using a preset per song. You can change the bank up/down to be preset up/down. You put your presets in the order of your set, and you are good to go.
I used the Helix Editor to create a custom setlist with the preset in the order that I needed.
Hi,Thanks a lot. Just was about to write my own findings in the manual, which I overread obviously:  Page 40 "Arranging Preset, Snapshot, and Stomp
Switches" > 4. Turn Knob 4 (Up/Down Switches) to customize FS1 and FS7 on the far left.
And it works. Quoting this from the manual might help others. :-)   . Regards
