David7700 Posted January 31, 2018 Share Posted January 31, 2018 I just bought the Relay G70 with one included TB516G and two extra TB516Gs. I want to upgrade to the latest firmware, but the Line6 Updater Utility does not seem to list any devices for me after I registered and installed the utility. Please let me know what steps I might be missing. I'm on a windows machine running Windows 10. Thanks. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted January 31, 2018 Share Posted January 31, 2018 Make sure you close any other applications accessing USB devices. Make sure you are connecting the devices directly to your computer's USB port with the supplied USB cable and not a USB hub. Quote Link to comment Share on other sites More sharing options...
JaseFIJo Posted February 2, 2018 Share Posted February 2, 2018 I have a similar issue at the moment, updated the base unit no problem, went to update the TB516G and the updater program states "The Transmitter was not detected correctly". I have opened ticket with support and are being helpful, so far have suggested. 1. http://line6.com/support/page/kb/_/live-sound/relay-digital-wireless/how-to-update-relay-g7075-transmitter-and-rece-r807 Make sure you've installed the latest version of Line 6 Updater (v1.12) and try updating in offline mode. For this, please download the TB516G flash memory file v1.03 from our website: http://line6.com/software/ Connect the transmitter via USB to your computer, launch Line 6 Updater, don't login, choose "offline mode" instead. Then select the downloaded file and try to repeat the update. Also test it with different USB ports and another USB cable. Don't connect to an USB hub. If still not working, please test it with another computer, if possible. Which I have been through, when I try and connect same report. I suspect that is a driver type issue maybe specific to Windows 10 which I have also running on a surface pro. Attached are the event reports for the device, where something is not finalising with the driver install. It is also suggested that your remove the batteries from the Transmitter for an update and there is a 5 secs on/off reset should things not go to plan If you are not seeing anything in the updater window then the device driver has probably not installed correctly or you have a cable fault. If you look in Devices and Printers you should see and Unspecified device called USB-Serial (Single Channel) - this is what mine registers as anyway. If you right click and run the trouble shooter it reports the device is a composite older USB that may not work with USB 3.0. So I'm off to find a USB 2.0 port on another machine! If I solve it or Support come up with something then I will post 1 Quote Link to comment Share on other sites More sharing options...
JaseFIJo Posted February 2, 2018 Share Posted February 2, 2018 I know think it's a USB3.0 v 2.0 fired up an old machine with Windows 10 and USM 2.0 ports 1. When plugging in the Transmitter the driver didn't auto load at first but the trouble shooter actually worked! and installed the driver. 2. Downloaded the Updater, logged in 3. Device recognised 4. Updated the firmware with no issues Not sure if this would be important but also had the auto sleep mode switch in the off position. Transmitter now at most recent firmware. Quote Link to comment Share on other sites More sharing options...
benowensofficial Posted February 15, 2024 Share Posted February 15, 2024 On 1/30/2018 at 9:57 PM, VirtualGuitars said: Make sure you close any other applications accessing USB devices. Make sure you are connecting the devices directly to your computer's USB port with the supplied USB cable and not a USB hub. I realize this is an old topic but felt I could offer alternative info relevant to current computer hardware. I actually had to use a hub with USB 2.0 ports to make it work because all of my onboard ports are USB 3.0. Quote Link to comment Share on other sites More sharing options...
