Difficulty updating (to 2.50 & other....)
sb77
Just now I struggled to get the updated firmware on to my Helix and was immediately getting an error generated as the update starts (this leaves a blank screen on Helix requiring a power cycle).This has happened before (2.3) and I believe(d) was attributable to internally shared usb on my laptop. Tried all ports having unplugged any peripherals but there is still internal sharing going on - not that unusual in laptops. Tried different cables  , everything....
I then inadvertently made just one additional modification and shutdown an incoming 5 pin MIDI signal (from a rhythm gen)  into Helix (tempo LED FS switched from blue to red as you would expect) - next time I tried the update procedure it worked first time. Nothing else changed. Yep, that seems bizarre and perhaps just a coincidence, but keep it in mind if anyone else is having a hard time with the updater starting & failing in a similar manner.
