erictye Posted February 10, 2018 Share Posted February 10, 2018 I've updated it 2 x now and the start screen shows 2.50 but theres no new amps etc on my list. No "legacy" file that I can find. PLEASE HELP!!! Quote Link to comment Share on other sites More sharing options...
spikey Posted February 10, 2018 Share Posted February 10, 2018 So you installed the new 2.51 editor, backed up the patch settings in Helix (2.30), then installed the 2.50 firmware via Line-6 updater (after you updated it), correct? And after you did all of this, you cant find the two new amps or any new legacy effects? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 10, 2018 Share Posted February 10, 2018 Check the Helix first to make sure it is on firmware version 2.50. Look under an effects category like Delay. You should see a Mono, Stereo, and Legacy list. The new effects are under Legacy. You did not mention if you were not seeing the new amps and effects on the Helix or on the Editor. If you are not seeing them on the Helix you probably did not have a successful upgrade to the 2.50 firmware. If you did not see them in the Editor you need to follow Spikey's instructions above and get upgraded to the 2.51 Editor. To see the new preset(s) you will have to do backup and then a global reset of the Factory setlists and then a restore or your user setlists as documented several other places on the forum. Quote Link to comment Share on other sites More sharing options...
erictye Posted February 11, 2018 Author Share Posted February 11, 2018 Ok, solved. Didn't realize that edit had to be updated too. Thanks for the quick responses. Quote Link to comment Share on other sites More sharing options...
