jikou Posted February 19, 2018 Share Posted February 19, 2018 As Spider V Firmware 1.05 Release Notes promises: "New Global setting: "Phones Mode" switches the headphone output between normal operation (Phone) and stereo line out (Line) for connecting to a mixer or audio interface without muting the speakers. In Line out mode, the headphone output is not affected by the position of the master volume, nor the presence of a cable inserted into the Phones jack. This is primarily for use on a Spider V that does not include XLR outputs."I upgraded firmware on my Spider V 60, but this does not work for me, mode "line" mutes speakers. Quote Link to comment Share on other sites More sharing options...
VartanK Posted February 24, 2018 Share Posted February 24, 2018 How do you switch modes? I can try it on my spider V 240. It’s updated but currently in phones mode Quote Link to comment Share on other sites More sharing options...
VartanK Posted February 25, 2018 Share Posted February 25, 2018 *Update* I figured out how to use the new feature provided in the Line 6 Spider V Firmware 1.05. Press and hold the home button on the face of the amp. Now several options are available, dial the selector knob until you find "phones mode" press the selector knob to switch between "phone" and "line" Selecting "line" will lock the output levels of the headphone jack as well as the XLR output. (master knob will now have no effect on them) Master knob attenuates only the speaker volume. Plugging a 1/4 inch jack into the phones output will not mute the speaker selecting "phone" will allow the master knob to attenuate the headphone output, as well as the XLR output. Plugging a 1/4 inch jack into the phones output will mute the speaker If you are having the same issue I have with recording levels on a SpiderV240, then "phone" is the way to go. I find the line level is pretty hot in my audio interface [steinbgerg UR22] and I need the master knob to turn it down, as my input level control may not be enough to keep it from peaking in the red Now back to your issue, I think I had something buggy happening on the SpiderV240 today, as the speaker was unexplainably muted {headphone jack removed]. When I switched modes from Phone to Line and back to phone again, it went away. Quote Link to comment Share on other sites More sharing options...
Stinger_Six Posted March 9, 2018 Share Posted March 9, 2018 I'm having a similar issue with my V 60. Plugging the headphones in would mute the speaker, removing them would un-mute. But after a couple weeks of use, unplugging the headphones would no longer un-mute the speakers. My workaround was to switch to 'Line' mode to use the amp without the headphones. Tried a firmware update, factory reset, nothing seems to work - if headphones aren't plugged in, no sound from the speakers unless I switch the Phones mode to 'Line'. Quote Link to comment Share on other sites More sharing options...
jikou Posted March 22, 2018 Author Share Posted March 22, 2018 Works for me now, successful process was following: Plug-in jack 3,5 M line cable connector Invoke firmware settings by holding “Home” button Change “Phones Mode” option from Phones to Line Loadspeakers are unmuted.Firmware remembers this option but not this behavior. After combo is switched off and on, the whole procedure must be repeated, now with “Phones Mode” option from Line to Phones and back to Line. It seems to me that system must “sniff” jack plugged in the slot first to start desired action. Quote Link to comment Share on other sites More sharing options...
jikou Posted March 22, 2018 Author Share Posted March 22, 2018 Thank you all who helped me. Quote Link to comment Share on other sites More sharing options...
coolies Posted July 11, 2018 Share Posted July 11, 2018 Thank you, thank you! Quote Link to comment Share on other sites More sharing options...
ak84 Posted January 11, 2024 Share Posted January 11, 2024 I have a similar but not exactly the same problem with my Spider V30 MkII. I can not easily switch between "Headphone" and "Line out" modes. Even when "Line out" mode is set up no sound is heard from the speaker when Spider is switched on, i.e. it is working in the "Headphone" mode. To switch into the "Line out" mode I have to unplug the jack from the socket, go into the "Settings" menu, switch to the "Headphone mode", then switch back to the "Line out" mode and only then plug the jack back into the socket. That is disturbing as unplugging and plugging jacks right on the stage can produce unnecessary and loud pops and clicks. Something is not very good with the "Phones/Line out" socket. Quote Link to comment Share on other sites More sharing options...
