husker636 Posted February 22, 2018 Share Posted February 22, 2018 Hi there Long time lurker and first time poster... Just got my Helix rack and I'm trying to work out to transmit multiple commands simultaneously with a single foot switch press and then transmit a different set of commands with a subsequent "pressings". My performance flow is that I have four basic presets and four snapshots within each preset (clean, drive, rhythm, lead) and then my main base is stomp mode with 8 foot switches to control various effects. Using the rotary as an example of what I would like to do... FS press 1: engage rotary at slow speed setting, simultaneously bypassing any amp cab blocks FS press 2: change rotary speed from slow to fast speed, add in drive block FS press 3: bypass rotary and drive block, simultaneously re-enabling amp cab blocks I've done extensive searches and read the manual but I can't work out how to do this (or if it is possible). I apologise if this has been covered - if so, please direct me to the relevant thread or Youtube video. If not, please would someone help me? Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 22, 2018 Share Posted February 22, 2018 With snapshots, doing all that with a single footswitch stomp would be easy. Really, I think that's the only way to do it. You might want to think about changing Preset Mode to be 8 Snapshots so you can access those additional snaps. Quote Link to comment Share on other sites More sharing options...
husker636 Posted February 22, 2018 Author Share Posted February 22, 2018 Thanks very much for your help. I suppose I worry that I will run out of snapshots. I could get another expression pedal and use that to control the rate. Is there any way I could do this with Midi? Quote Link to comment Share on other sites More sharing options...
