240 HC locks up and goes to feed back tone when playing backing track on iphone
cfppro123
Hi cfppro123, that doesn't sound like normal operation. First, make sure you are on the latest firmware. You can check the firmware on the amp by pressing and holding the home button. You can also perform a factory reset.; press and hold the home button and then scroll to and select the last option, factory reset. Be sure to back up any custom presets using the Spider remote app before performing the reset.
If all fails I would open a support ticket with Line 6.
https://line6.com/support/technical-support/
