xyphod Posted March 12, 2018 Share Posted March 12, 2018 Here is the issue. I have 4 snapshots. Snapshot 1) Gain is set to 2.0 on amp and I want to use the expression pedal to swell the gain from 2 to 5 Snapshot 2) Gain is set to 3.0 on amp and I want to use the expression pedal to swell from 3 to 6 Unfortunately I seem to only be able to start and end value at the patch level and not the Snapshot level? Any ideas? Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 12, 2018 Share Posted March 12, 2018 The min and max values for the expression pedal are per preset, so you can't have separate ones set per snapshot. If you the EXP Position parameter in Global Settings>EXP Pedals set to "Per Snapshot", you can have a specific value saved for that parameter in each snapshot. But once you move the pedal, the pedal will always toggle between the min and max values that you have it set to. Quote Link to comment Share on other sites More sharing options...
xyphod Posted March 12, 2018 Author Share Posted March 12, 2018 Damn, maybe a feature request, can't be that hard to implement. Quote Link to comment Share on other sites More sharing options...
