jfm0257 Posted March 16, 2018 Share Posted March 16, 2018 So, I'm aware of the flaw with using the two. I know it would be double modulating, which takes away the quality, but not by much. I'm having a hard time coming up with a good metal distortion sound. I don't know if it's how I have it currently set up. Basically what I have set on the Amplifi is that there are no effects, and the amp is set to "no amp" at 50%. I also want to know if I should you the distortion on the amp effects, or should I set the amp to a "clean" amp patch, and use distortion pedal patch. Quote Link to comment Share on other sites More sharing options...
ADBrown Posted March 19, 2018 Share Posted March 19, 2018 There are definitely a few ways to set this up considering both devices have amp and effect modeling. I would try setting up an amp tone you like in Amplifi, and use the Firehawk FX just for effects, essentially as just a pedalboard. For metal tones I would start with a higher gain amp as opposed to a clean one with stompbox distortion. You can always add more gain to the amp with an distortion/overdrive effect if needed. A generic starting point for metal tones is to also "scoop the mids" meaning reduce the mids on the amps EQ and accentuate the bass and treble. Quote Link to comment Share on other sites More sharing options...
