Snapshots
cgar18
Is there or will thee be a way to save amp changes in the snap shots. Unless im doing something wrong I would like to raise the bass and master and a few tweaks on the amp but leave the original setting that i created alone.When I do that and save it to another snapshot it carries the changes over to the original.I hope im explaining it right.
You can do this, but you have to assign those parameters to the snapshots controller. Assuming you are on floor or rack, you can do that by pressing down on the parameter knob as you turn. That will put the value in brackets and you'll be able to change them between snapshots
  • Thanks 1
